*surfaceimprintpoints
Imprints locations/points, given by coordinates, onto surfaces within a given max distance.
*surfaceimprintpoints mark_id double_array number_of_doubles max_distance
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the surfaces to imprint. Valid values are 1 and 2.
- double_array
- The ID of the double array that contains the point coordinates to imprint. The double array is created using the *createdoublearray command. This should always be set to 1.
- number_of_doubles
- Integer indicating the size (number of doubles) in the double array created using *createdoublearray. This should always be a multiple of 3.
- max_distance
- The maximum imprint distance. If negative, there is no restriction.
Examples
To imprint surfaces 5 and 7 with 4 locations:
*createmark surfs 2 5 7
*createdoublearray 12 42.41 -35.16 65.90 42.49 -30.06 65.93 44.49 -32.58 66.97 24.41 -28.13 66.34
*lineimprintpoints 2 1 12 -1.0
# Handle error
}Version History
2019
