*CE_ReadXmlString
Creates a connector from an XML string.
*CE_ReadXmlString string reserved1 reserved2
HyperMesh Tcl Modify Command
This command creates a connector from an XML string.
- string
- The string containing the XML connector definition.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
Examples
*CE_ReadXmlString <CE_Connectors><CE_Link_List NumberOfLinks="2"><CE_Link Type="comps" Id="1" Rule="none" State="elems" /><CE_Link Type="comps" Id="2" Rule="none" State="elems" /></CE_Link_List><CE_Spot Id="1"><Location><Cords>8.514332 0.150252 0.000000</Cords></Location><CE_Detail CompID="2" CompName="bottom_square" Thickness="2" /><FE_Detail Config="rigid" Tolerance="7.000000" FESolver="0" System="0" Connectivity="0" Nonnormal="0" /><CE_Metadata_List><CE_Metadata Type="Int" Name="ce_fe_acm_numhexa" Value="1" /><CE_Metadata Type="String" Name="ce_comp" Value="bottom_square" /></CE_Metadata_List></CE_Spot></CE_Connectors> 0 0Errors
# Handle error
}Version History
11.0.101
