*morphmaptosurfacevecoffset
Maps nodes to surfaces along a vector.
*morphmaptosurfacevecoffset entity_type_nodes mark_id_nodes entity_type_handles mark_id_handles entity_type_surfaces mark_id_surfaces use_symmetry use_constraints project vector_id mode offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, the specified plane using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the plane along a vector, normal to the plane, or projected normal to the elements touching the nodes.
- entity_type_nodes
- Must be set to nodes.
- mark_id_nodes
- The ID of the mark containing the nodes. Valid values are 1 and 2.
- entity_type_handles
- Must be set to handles.
- mark_id_handles
- The ID of the mark containing any following handles. Valid values are 1 and 2.
- entity_type_surfaces
- Must be set to surfaces.
- mark_id_surfaces
- The ID of the mark containing the surfaces to map to. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry (only option)
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- mode
- 0 - If *morphmaprecalc has been used to calculate new influences
- offset
- The distance to offset nodes from the target.
To map nodes on mark 1 to surfaces on mark 1 with an offset of 1.2 when not using *morphmaprecalc:
*morphmaptosurfacevecoffset nodes 1 handles 1 surfs 1 0 1 2 1 1 1.2
# Handle error
}Version History
14.0.110
