*tableupdatelabels
Updates the column labels of a table.
*tableupdatelabels name string_array number_of_strings
HyperMesh Tcl Modify Command
- name
- The name of the table to update.
- string_array
- The ID of the string array that contains the column labels to update. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray. This must equal the number of columns in the table.
To update the labels for table1 with 3 columns:
*createstringarray 3 "Name" "ID" "Thickness"
*tableupdatelabels table1 1 3
# Handle error
}Version History
11.0
