*surfacemarksplitwithline
Splits a mark of surfaces with a line swept along a vector.
*surfacemarksplitwithline mark_id line_id vector_id trim_flag distance
HyperMesh Tcl Modify Command
This command splits a mark of surfaces with a line swept along a vector.
- mark_id
- The mark ID containing the surfaces to split. Valid values are 1 and 2.
- line_id
- The line ID to use for splitting.
- vector_id
- The vector ID to use for the split direction. This is defined using the *createvector command.
- trim_flag
- 0 - The line is swept using the distance value.
- distance
- The distance to sweep, if trim_flag is 0.
*createmark surfaces 1 10 20
*createvector 1 0.0000 0.0000 1.0000
*surfacemarksplitwithline 1 11 1 1 0Errors
# Handle error
