*imprint_geom
Imprints, connects source points, nodes, lines and surfaces onto target FE surfaces.
*imprint_geom entity_type_target mark_id_target entity_type_source mark_id_source ?options?
HyperMesh Tcl Modify Command
Imprints, connects source points, nodes, lines and surfaces onto target FE surfaces. This command does not support surfaces that are not FE. Points and lines could be any type. In the case that input is an FE entity, the command optionally remeshes the input entities.
- entity_type_target
- The type of entity to use as the target (destination) for the imprint. Valid values are surfaces.
- mark_id_target
- The ID of the mark containing the target (destination) entities to imprint. Valid values are 1 and 2.
- entity_type_source
- The type of entity to use as the source for the imprint. Valid values are points, nodes, lines, surfaces.
- mark_id_source
- The ID of the mark containing the source entities to imprint. Valid values are 1 and 2.
- options
- List of input options, passed as a space separated string enclosed in quotes. Valid
options are:
- angle <value>
- The angle used to define feature edges on the mesh. If not defined, 25.0 is used.
- max_distance <value>
- The command will exit with an error if the distance between source and destination exceeds this value. If not specified, this is ignored.
- mesh_size <value>
- Automatically detected from input mesh if not provided.
- mesh_type <value>
- projection_vector <x y z>
- 3 doubles defining the vector direction. If not defined, normal projection is used.
- remain <value>
- 1 - Source remains, source node coordinates are kept (default if not provided)
- remesh_mode <value>
- -1 - No remesh. Element connectivity is maintained by recovery of the imprinting element edges.
- remesh_layers <value>
- Must be defined if remesh_mode is 2.
- to_dest_component <value>
- 0 - Do not organize imprinted elements to destination component (default if not provided).
Examples
To imprint surfaces 20 and 21 onto surface 45, using a normal projection, a feature angle of 30, keeping the source, and remeshing the destination using 2 layers:
*createmark surfs 2 20 21
*createmark surfs 1 45
*imprint_geom surfs 2 surfs 1 "remain 1 remesh_mode 2 remesh_layers 2 angle 30.0"
# Handle error
}Version History
2019
