hm_wadlinessetentities
Sets the entities used for a WAD lines analysis.
hm_wadlinessetentities entity_type_front mark_id_front mode_or_entity_type_rear mark_id_rear
HyperMesh Tcl Query Command
- entity_type_front
- The entity type denoting the front of the vehicle (bumper, bonnet, fenders). Valid values are elems, surfs and comps (elems take priority over surfs).
- mark_id_front
- The ID of the mark containing the front entities. Valid values are 1 and 2.
- mode_or_entity_type_rear
- One of the following:
- mark_id_rear
- The ID of the mark containing the rear entities if mode_or_entity_type_rear is a specific entity type, or blank if one of the strings is used. Valid values are 1 and 2.
Examples
To setup and extract WAD lines data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesend
The above example can be modified instead to put all entities on the first mark:
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR" "windshield" "a-pillars"
hm_wadlinessetentities comps 1 all_in_one
The example can be modified instead to only run a bumper analysis:
hm_wadlinessetentities comps 1 front_only
# Handle error
}Version History
12.0.110
