hm_updatemodelcheckresultvalues
Updates the failed values for the model check entity.
hm_updatemodelcheckresultvalues display_name
HyperMesh Tcl Query Command
- display_name
- The check display name.
To update the model check entity with ID 2 and name check_volume:
*createstringarray 3 0.5 1 1.5
*attributeupdatestringarray modelcheckchecks 2 100230 1 2 0 1 3
hm_updatemodelcheckresultvalues "check_volume"
# Handle error
}Version History
2019.1
