hm_getmaxgapwidth
Returns the approximate maximum distance between a pair of node lists.
hm_getmaxgapwidth list_id1 list_id2
HyperMesh Tcl Query Command
Returns the approximate maximum distance between a pair of node lists. This is useful for determining the gap width to be used for filling the gap between the node lists.
- list_id1
- The ID of the first node list. Valid values are 1 and 2.
- list_id2
- The ID of the second node list. Valid values are 1 and 2.
Examples
To get the maximum gap width between two node lists:
*createlist nodes 1 1-20
*createlist nodes 2 45-80
hm_getmaxgapwidth 1 2
# Handle error
}Version History
14.0.130
