hm_comparewriteresults
Writes the current comparison results to a file.
hm_comparewriteresults filename ?source_component_id? ?target_component_id?
HyperMesh Tcl Query Command
Writes the current comparison results to a file. This must be preceded by a call to a relevanthm_compareentities* command.
If hm_comparesetflags is set to 1, the pairwise data can be seen in the output file, otherwise the legacy output will be generated. The optional arguments are only valid when hm_comparesetflags is set to 1.
- filename
- The full name and path of the file to write the results to.
- source_component_id
- If ignored, or set to 0, all the compared data corresponding to all source components will be generated. If a valid source ID is given, the compared data for the corresponding source component is generated.
- target_component_id
- If ignored, or set to 0, all the compared data corresponding to all target components will be generated. If a valid target ID is given, the compared data for the corresponding target component is generated.
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0
hm_comparewriteresults C:/temp/my_compare.txt
hm_compareend*createmark elems 1 "by assems" 1
*createmark elems 2 "by assems" 2
hm_compareinit
hm_comparesetflags 1
hm_compareentitiessameside elems 1 elems 2 1.0 2 0
hm_comparewriteresults C:/test/pairwise_compare.txt
hm_compareinit
hm_comparewriteresults C:/test/pairwise_compare.txt 10 20
hm_compareendErrors
# Handle error
}Version History
12.0
2020 - Added new options source_component_id and target_component_id.
