MBS Joints Panel
Use the MBS joints panel to define kinematic joints between two local coordinate systems to connect two multibody collectors. The Engineering Solutions entity created is an mbjoint.
The panel contains an organize systems option. When activated (default) during joint creation, two coordinate system collectors will be automatically created and the joint local coordinate systems will be placed in their respective collectors. Since joint local coordinate systems are usually coincident in global space (but not required), the "organize systems" option provides easy access to each joint system.
Care should be taken when creating joints without coincident joint coordinate because the exported model might not reflect the model in Engineering Solutions.
Joint types are defined by assigning a card image in the card image= field (in some solver interfaces, it is the type= field). If no card image is assigned, all DOFs are active.
The available joint types are dependent on the template file loaded with the solver interface.
- Referencing the child multibody collector's coordinate system to the joint child coordinate system.
- Referencing the joint child coordinate system to the joint parent coordinate system.
- Referencing the joint parent coordinate system to the parent multibody collector's coordinate system.
When an mbjoint entity is deleted in the Delete panel, the joint's child coordinate system is referenced to the global coordinate system.
Create Subpanel
| Option | Action |
| name = | Specify a name for the new joint. |
| card image = / type = | Select a card image. Note: In some solver
interfaces this button is replaced by type =.
| parent: color | Select a color for the parent entity of the joint. |
| parent: syst | Select the joint parent's coordinate system. |
| parent: multibody / reference space |
| mbjoint: color | Select a color for the joint. |
| child: color | Select a color for the child entity of the joint. |
| child: syst | Select the joint child's coordinate system. |
| child: multibody | Select the multibody collector that defines the joint's child body. |
| organize systs | Separate the joint coordinate systems into new coordinate system collectors. |
Update Subpanel
| Option | Action |
| name = | Select an existing MBS joint. |
Select a card
image. Note: In some solver interfaces this
Card Image Subpanel
| Option | Action |
Command Buttons
| Button | Action |
| create | Create the new MBS joint. |
| create/edit | Create the new joint and open its assigned card image in edit mode. |
| update | Change the selected joints to use the current input settings. |
| edit | Edit the current MBS joint's card image. |
| load | Load the selected MBS Joint's card image. |
| load/edit | Load the selected MBS Joint's card image and display it in edit mode. |
| reject | Undo the most recent joint creation or update. |
| reset | Reset the joint's input settings to their original values. |
| reset all | Reset all MBS joints in the model their original values. |
| return | Exit the panel. |
