On Plane Panel
Use the On Plane panel to select entities that are on or touch a plane.
Location: Accessed from the Extended Entity Selection menu
You can select nodes, elements, components, lines, surfaces, points, and contactsurfs that are on a plane within a given tolerance. You can also select entities that are on a vector normal to a plane (at the base point).
When selecting nodes or elements on a plane (plane toggle), Engineering Solutions determines the plane and selects all the nodes or elements that are within a given tolerance from that plane. All components whose elements are on the plane can be found. You can also find lines or surfs that simply touch the plane, or those that are entirely on the plane (within tolerance).
When selecting entities on the normal to plane, Engineering Solutions determines a normal vector at the base point selected and then finds all the entities that are within the tolerance of that vector.
Panel Options
| Option | Action |
| plane and vector selector | Select the plane.
Entities within the tolerance= value of this plane will be selected in the entity selector from which the panel was accessed. |
| tolerance = | Specify the distance that entities are permitted to be from the defined plane and still be selected. Entities beyond this distance will not be selected. |
| plane / normal of plane | Select whether the
selection is bi-directional or not.
Command Buttons
| Button | Action |
| create | Create the new objective entity. |
| update | Update the selected objective entity. |
| review | Populate the fields
with data.
| return | Exit the panel. |
