Dummy Panel
Use the Dummy Positioning / Joint dof panel to rotate the dummy assemblies or specify the position of the H-Point of a dummy assembly. The dummy database must be organized as a tree structure.
Incremental Subpanel
| Option | Action |
| entity selector | Select components or multibodies. |
| rotate: child / parents | Select whether to rotate around the child or parent system when rotating the assembly. |
| increment | Specify the amount by which to increment the angle between stops. |
| x / y / z rot | To rotate the dummy to the min stop or max stop of the x-axis, y-axis, or z-axis, click the corresponding symbols, << or >>. |
| min stop | The min stop angle for the x, y, z, axis associated with the joint is retrieved from the dummy database. When the minimum angle is reached, the assembly is not allowed to rotate any further. |
| current | The current position. |
| max stop | The max stop angle for the x, y, z, axis associated with the joint is retrieved from the dummy database. When the maximum angle is reached, the assembly is not allowed to rotate any further. |
H-Point Subpanel
| Option | Action |
| position: coordinate / point - node | Specify the coordinate values or select the node at which you want the H-point located. |
| rotate selector | Specify the plane or axis around which to rotate |
| increment | Specify the amount to rotate. |
Command Buttons
| Button | Action |
| position | Position the dummy. |
| reject | Reject the current selection. |
| rotate + / rotate - | Rotate the component in the positive or negative direction. |
| return | Exit the panel. |
- FTSS/Arup FE Dummies for Dyna3D
- The Dyna3D keyword import translator detects the use of an FTSS/Arup dummy and builds the required tree structure automatically.
- PAM-CRASH 2G Dummies
- Altair provides an external translator that converts a GENERIS tree file into Engineering Solutions commands. After importing the dummy, you need to run this command file once to establish the required tree structure in Engineering Solutions.
- Other Dummy Models/Mechanical Systems
- The Dummy Positioning panel works for any FE mechanical system (comprised of joints and local coordinate systems) as long as the appropriate tree structure exists. If the tree structure does not already exist in the system of interest, you can use the Systems panel to create the necessary references.
