Node Based Surface
Use the Node Based Surface dialog to define and edit the *SURFACE, TYPE = NODE card.
The Node Based Surface dialog contains the following
buttons:
| Button | Action |
| Surface color | Changes the color of the current surface in the graphic area. |
| Review | Reviews the current surface by highlighting it in white and displays it through solid mesh in the graphic area. If the surface is defined with sets, the underlying nodes are highlighted. Right-click Review to clear the review selections. |
| Close | Updates the Engineering Solutions database with the optional parameters specified and closes the Node Based Surface window. |
