Analytical Rigid Surface
Use the Analytical Rigid Surface dialog to define the *SURFACE, TYPE = CYLINDER, REVOLUTION or SEGMENTS card.
When you click Create, the Analytical Rigid Surface dialog opens.
Each tab of the Analytical Rigid Surface dialog contains the
following buttons:
| Button | Action |
| Surface color | Changes the color of the current surface in the display. |
| Review | Reviews the current surface by highlighting line segments and generated revolute or swept surfaces in white. Right-click on the Review button to clear the review selections. |
| Close | Updates the Engineering Solutions database with the optional parameters that you specified and closes the Analytical Rigid Surface window. |
