Supported Nastran Solutions
| Functionality | HyperView | HyperGraph 2D |
| Reads model file directly | DAT, OP2 | N/A |
| Reads results file directly | OP2 | PCH, OP2 |
| Reads translated results | PCH (hmnast: HMRES and H3D) OP2 (hmnast02:HMRES and H3D) |
PCH (hmnast: HMRES) OP2 (hmnast02:HMRES) |
| Supported SOLs | PCH translated: 101, 103, 105, 106, 107, 108, 109, 110, 111, 112 | PCH translated: 101, 103, 105, 106, 107, 108, 109, 110, 111, 112 |
| PCH direct: 108, 109, 110, 112 | ||
| OP2 translated: 101, 103, 105, 106, 107, 108, 109, 110, 111, 112 | OP2 translated: 101, 103, 105, 106, 107, 108, 109, 110, 111, 112 | |
| OP2 direct: 101, 103, 105, 107, 108, 109, 110, 111, 112 | Same as HyperView. | |
| Nastran version supported | 2007 | 2007 |
| Supports complex (operating modes) results | Yes | Yes1 |
| Nastran centroidal results | Yes2 | Yes |
| Nastran corner results | Yes3 | Yes |
| Transforms results to other system type in application | Yes | N/A |
| Transform any tensor to vector results | Yes | N/A |
| Supports 1D elements - Model | Yes | N/A |
| Supports 1D elements - Results | Yes4 | Yes5 |
| Supports mass entities in model | No | N/A |
- In HyperGraph 2D, displacement, acceleration, force, and velocity are supported. Stress and strain are not supported.
- Nastran centroidal results in HyperView: With the Average color option on, HyperView averages element values to nodes to create a smooth contour plot. You can query elements for centroidal values, but not averaged values, at nodes. With the Average color option on or off, the contour plot reflects exactly what is in the results file.
- Nastran corner results in HyperView: When using the Display contour data option to create a contour plot, HyperView uses a simple average at nodes. The legend reflects corner results. You can query elements for node values, but you cannot query calculated average values. When you are not using the Display corner data option to create a contour plot, HyperView uses the element values in the results file.
- Supports stress, strain, and force for CELAS, CROD, CBAR, and CBEAM.
- Supports 1D elements (CBUSH, CELAS, CDAMP) forces in SOL 108/111.
