Dyna External Readers
| Option | Description | Supports |
| ABSTAT | Airbag statistics. Reads airbag and blocked materials statistics from LS-DYNA files into HyperGraph 2D. The data read in is sorted by time steps specified in the input file. |
Volume, pressure, internal energy, input mass flow rate, output mass flow rate, mass, temperature, and density. |
| BNDOUT | Boundary condition forces and energy. | x, y, z force |
| DEFGEO | Deformed geometry file. The NASBDF file (Nastran Bulk Data) is created whenever the DEFGEO file is requested. | |
| DEFORC | Discrete elements. | x, y, z force |
| ELOUT | Element data. | Beam
Stress Shell
Brick
Strain Shell
| GCEOUT | Geometric contact entities. | Translational Components
Rotational Components
| GLSTAT | Global data. Always obtained if SSSTAT file is activated. | kinetic energy internal energy total energy ratio stonewall-energy spring and damper energy hourglass energy damping energy sliding interface energy external work x, y, z velocity time step Element ID controlling time step |
| JNTFORC | Joint force file. | x, y, z force x, y, z moment |
| MATSUM | Material energies. | kinetic energy internal energy hourglass energy x, y, z momentum x, y, z rigid body velocity total kinetic energy total internal energy total hourglass energy |
| NCFORC | Nodal interface forces. | x force, y force, z force |
| NODFOR | Nodal force groups. | x, y, z force |
| NODOUT | Nodal point data. | x, y, z displacement x, y, z velocity x, y, z acceleration x, y, z rotation x, y, z rotational velocity x, y, z rotational acceleration |
| RBDOUT | Rigid body data. | x, y, z displacement x, y, z velocity x, y, z acceleration |
| RCFORC | Resultant interface forces. | x, y, z force |
| RWFORC | Wall forces. | normal x, y, z force |
| SBTOUT | Seat belt output file. | |
| SECFORC | Cross section forces. | x, y, z force x, y, z moment x, y, z center area resultant force |
| SLEOUT | Sliding interface energy. | secondary energy main energy |
| SPCFORC | SPC reaction forces. | x, y, z force x, y, z moment |
| SSSTAT | Subsystem data. | |
| SWFORC | Nodal constraint reaction forces (spotwelds and rivets). | axial force shear force |
