hgthp
| Description | Supports | Does Not Support |
| Reads PAM-CRASH and PAM-CRASH 2G THP files (time history
files generated by the solver) into HyperGraph 2D.
Also reads ASCII files generated by exporting curves from PAMVIEW. hgthp can be run from the command prompt to convert THP files into Altair Binary Files (ABF files). PAM-CRASH 2003 THP files are also supported. No ESI license is required to use this reader. |
The PAM-CRASH 2G and PAM-SAFE
options. Solid Elements
The PAM-STAMP option. |
