abstat_mat
| Option | Description | Supports |
| ABSTAT | Airbag statistics. Reads airbag and blocked materials statistics from LS-DYNA files into HyperGraph 2D. The data read in is sorted by time steps specified in the input file. |
Volume, pressure, internal energy, input mass flow rate, output
mass flow rate, mass, temperature, and density. Airbag material leakage (from LS-DYNA R11.1). |
