Readers, Writers, and Functions
Register import templates, external readers, external functions, and export templates in the current session or add them to the current preferences.mvw file.
The following tabs are included:
- Import Templates
- Register import templates in the current session, append import templates to the current preferences.mvw file, or save registered import templates to a new preferences.mvw file.
- External Readers
- Register external readers in the current session, append external readers to the current preferences.mvw file, or save external readers to a new preferences.mvw file.
- External Functions
- Register external functions in the current session, append external functions to the current preferences.mvw file, or save external functions to a new preferences.mvw file.
- Export Templates
- Register export templates in the current session, append export templates to the current preferences.mvw file, or save registered export templates to a new preferences.mvw file.
- Register
- Adds the selected reader, writer, function, or template to the current list in the Readers, Writers, and Functions dialog.
- Save as…
- Saves selected readers, writers, and functions to a new preferences.mvw file.
- Append
- Once the selected reader, writer, function, or template is registered, Append adds it to the preferences.mvw file in your working directory.
Debugging
If you experience problems loading a curve in HyperGraph 2D, create the environment variable "READER_TIMING"=<Log File
Path>. This file logs the time each reader takes to check the file
format and load the file upon a positive match.
