Supported Files in HyperGraph
HyperGraph can read the following types of plot data files:
| File Type | Description |
| Abaqus | ODB Mass from DAT files |
| AcuSolve | *.Log files |
| ADAMS | REQ and matrix files |
| Animation | Animation files are used to view and animate simulation results.
Animation files can only be opened in HyperView using the file browser icon on the toolbar. The following animation files are supported
in HyperGraph:
| Animator | *.a4db Animator database files. |
| ASAM ODS | *.atfx with supporting BTF file. |
| DADS | Graph files |
| DATX | DATX and DATX_index files |
| Diadem XML | TDM TDX TDMS |
| Exodus solver result files | .ex2 .frq |
| Flux | Text files |
| General | Excel (CSV) Multi-column ASCII XYDATA files (an example can be found in your installation directory under <installation directory>\demos\mv_hv_hg\plotting\general). User-defined import templates and external readers to directly read any file format Tab delimited files |
| HBM Temperature Measurement Test Data | *.tem |
| HyperWorks | HyperForm DAT files HyperMesh RES files MotionSolve files MotionView shock output files OptiStruct files Radioss files |
| International Organization Standardization (ISO ) | MultiMedia Exchange data files |
| LS-DYNA Time History Files | ABSTAT BNDOUT DBFSI DISBOUT DEFGEO ELOUT GCEOUT GLSTAT JNTFORC Mass from D3HSP MATSUM NODFOR NODOUT RBDOUT RCFORC Rotational SPC for BINOUT files only RWFORC SBTOUT SECFORC SLEOUT SMDYN6 SPCFORC SPHOUT SSSTAT for ASCII and BINOUT files SWFORC TRHIS |
| MADYMO Time History Files | TQ3 |
| Nastran | Mass and frequencies from f06 file Complex results from SOL 108
and 111:
| PAM-CRASH Time History Files |
PAM-CRASH 2G ERFH5(HDF5) and THP Support for time history results using the environment variable ALTAIR_PAM_HDF5_REQUEST_TYPE. If the value of this variable is set to NAME_ID, name and ID are shown in the request list of the Build Plots panel; if the value is set to “ID”, only the ID is shown. |
| Radioss | Radioss animation files for "IIHS Front intrusion - 40%" |
| Simpack | RSP files |
| TiemOrbit property files | *.bus *.reb *.dpr *.spr *.bum |
| Other File Types | WINGZ
Test
Ride data files RPC-3 Altair SDFS files DIADEM DAT header files HDF 4.0 ISO 13499 MME UNV Block 58 Gauge time history output |
