hgradioss
| Description | Supports | Does Not Support |
| Reads Radioss T01 files (result files generated by the solver) into HyperGraph 2D. | Global
Variables PARTS PROP MAT NODE BRIC QUAD SHEL, SH3N BEAM TRUSS SPRING ACCEL SECTIO CYL_JO MONV RWALL RBODY INTER SUBS |
NSTRAND |
Usage
- hgradioss(.exe) –f fileT01 outfile
- By default, this reader is registered. If not, please register it before reading T01 files directly into HyperGraph 2D. It is located in the HWDIR\externalreaders\ directory.
