hgdaisy
| Description | Supports | Does Not Support |
| Reads PAM-CRASH and PAM-CRASH 2G DSY files (results files
generated by the solver) into HyperGraph 2D. No ESI license is required to use this reader. PAM-CRASH 2003 DSY files are also supported. |
NODES
SOLIDS
Stamp options |
Usage
- -hgdaisy dsyfile outfile
- By default, this reader is registered. If it is not, please register it before reading DSY files. It is located in the HWDIR\externalreaders\bin\$PLATFORM\plot directory. After registering the reader, you can read DSY files directly into HyperGraph 2D.
