Load Step: RADIATE
In the RADIATE dialog, define the *RADIATE cards on individual elements or geometry (surfaces). You can also define the RADIATE on element sets.
To open this dialog in the Load Step window, select RADIATE from the tree and a load collector from the Load collector table.
Load Step: RADIATE: Define Tab
In the Define tab, define *RADIATE cards on individual elements or geometry (surfaces) as well as on element sets.
- Elements or geometry
- Element sets
The layout of the Define tab changes, based on your selection.
Define RADIATE On: Elements or Geometry
Use the Define RADIATE on: Elements or geometry option to define RADIATE on individual elements or geometric surfaces.
RADIATE loads created on elements have special graphical display in Engineering Solutions. Loads created on geometric entities like surfaces are automatically mapped to FEA mesh on export. You can also map them using the Map Loads on Geometry button.
| Button | Action |
| Define from Pressures panel | Opens the Pressures panel, from which you can create and
update RADIATE. It only allows you to define the reference sink
temperature. To create a RADIATE on elements, go to the create subpanel, select elems using the switch, pick the desired elements from the Engineering Solutions graphics, click nodes, pick two or three nodes from a face of a selected element, input the magnitude (sink temperature), and click create. To create a pressure on
geometry, go to the create subpanel, select
surfs using the switch, pick the
desired geometry from the Engineering Solutions
graphics, input the magnitude (sink temperature), and click
create.
Note:
| Map Loads on Geometry | Opens the Engineering Solutions Loads on Geom panel to
map loads on geometry to FEA mesh entities. Click the
Map loads button to map all
geometric loads in the current load collector to FEA entities.
Note:
Define RADIATE On: Element Sets
Use the Define RADIATE on: Element sets option to define the radiation conditions on element sets. It is possible to apply RADIATE on element sets and components.
This dialog contains a drop down menu containing a list of the existing element sets or components. There are two types of element sets in Engineering Solutions: components and entity sets. The Abaqus element sets that are linked to sectional property cards, such as *SOLID SECTION and *SHELL SECTION, become components in Engineering Solutions upon import. To differentiate between these two types, there is a divider line "- - - - -" in the element set list that pops up if you open up the extended entity selection ([…] – button). The elsets listed below the divider line are components.
| Column | Description |
| Elset | The name of the element sets. Element sets are added and deleted in this column using → or ←, respectively. |
| Label | The labels of RADIATE load. The available labels are: R1, R2, R3, R4, R5, R6, RPOS, and RNEG. |
| Ref temp | The reference ambient temperature. |
| Emissivity | Surface emissivity |
| Load Id | The ID of the load collector. |
| Button | Action |
| Review Set | Reviews the selected node sets by highlighting them in the Engineering Solutions graphics. Right-click Review to clear the review selections. |
| Create/Edit Set.. | Opens the Entity Sets panel in Engineering Solutions. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the element set list. |
| Display/Review from panel | Opens the appropriate Engineering Solutions panel. Use the review button to expand the loads and constraints on the sets for visualization purposes. |
| → | Add the selected node set from the drop-down menu to the data line table on the right. |
| ← | Delete the selected node set from the data line table. |
| Show Faces | Used mainly to review the face identifiers of elements in the
selected set. It creates a temporary skin of the selected elset,
opens the Element Selector panel, from which you can select face
elements from this skin. When you return from the element
selector panel, the selected faces will display color-coded face
identifier tags. In performance graphics, these tags are
sometimes blocked by the solid mesh. You may need to rotate the
model a little to view the tags. Right-click Show faces to clear the face review. |
| Review | Creates special review RADIATE loads in Engineering Solutions graphics for the selected set. Right-click Review to clear the special review loads and highlighting. |
| Update | Updates the Engineering Solutions database with the data lines defined in the table. By default, Engineering Solutions does not create a display for loads defined with sets. |
For tips on entering information and navigating in the Define tab, see Step Manager Tab Environment.
Load Step: RADIATE: Delete Tab
In the Delete tab, delete *RADIATE and other loads.
| Option | Description |
| All loads in current collector | The Delete button deletes all the loads from the current load collector. |
| All 'Distributed loads' in current collector | The Delete button deletes all distributed (*DLOAD, *RADIATE) loads from the current load collector. |
| By selection | The Pick Loads button opens the Engineering Solutions
load selector panel. Pick the loads you want to delete and click
proceed. The corresponding Reset button resets the selected loads. The Delete button deletes the selected loads. |
Load Step: RADIATE: Parameter Tab
In the Parameter tab, define optional parameters for the *RADIATE card.
The supported parameters include: Amplitude curve, OP, and Region Type.
Click Update to activate the optional parameter selection in the Engineering Solutions database.
Modify the Emissivity
Options for defining the emissivity for a RADIATE card created on individual elements or geometry.
- By selection
- The Pick loads button opens the Engineering Solutions Load Selector panel. Pick the RADIATE loads to which you want to assign emissivity, and click proceed.
- The corresponding Reset button resets the selected loads.
- The Update button assigns the value specified in the Emissivity: field to all selected RADIATE loads.
- All RADIATE in current collector
- The Update button assigns the value specified in the Emissivity: text box to all the RADIATE loads in the current load collector.
In a similar way, for shell elements, it is possible to change the element face (RPOS or RNEG) on which the RADIATE load is applied.
