Context Menu
Use the Subsystem Browser context menu to invoke key functions and visualization options. Options vary based on the entity type selected.
| Option | Description |
| Create | Create a new empty subsystem. |
| Delete | Delete the selected entity. Use the Also Delete Children Entities checkbox to delete the selected entity and all of its contents. |
| Rename | Rename the selected entity. |
| Representations | Displays the Representations sub-menu. |
| Library | Displays the Library sub-menu. |
| Export Deck | Writes out the subsystem as an include solver deck. |
| Show | Displays the selected entity in the graphics area. |
| Hide | Hides the selected entity in the graphics area. |
| Isolate | Isolates the selected entity, hiding all other entities of the same type. |
| Isolate Only | Isolates the selected entity, hiding all other entities. |
| References | Displays the Reference Browser for the selected entities. |
| Expand | Expands the selected entity folder(s). |
| Collapse | Collapses the selected entity folder(s). |
| Organize Settings | Opens Organize Settings options to customize which dependent entities are also moved when organizing subsystems. |
| Configure Browser | Opens local Configure Browser options. |
