| Id of component out of bounds |
Checks if there are any component ids that are either less
than the min_limit or more than the max_limit of allowable ids
in the ID Manager. |
List all of the components with ids outside of the
limit. |
Not supported. |
Opens the Renumbers panel. |
| Component missing material |
Checks if the components with card image PART / are
associated with the correct material based on their element
content. |
Lists all components that do not have the correct materials
associated to them. |
Not supported. |
Opens the Components panel. |
| Component does not have a part card |
Checks if the components defined in Altair HyperMesh are not
assigned with card image PART / . |
Lists all components that do not have a card image. |
Not supported. |
Not supported.
| Id of material out of bounds |
Checks if there are any material ids that are either less
List all of the materials with ids outside of the
limit. |
Not supported. |
| Id of property out of bounds |
Checks if there are any property ids that are either less
List all of the properties with ids outside of the
limit. |
Not supported. |
| Id of group out of bounds |
Checks if there are any group ids that are either less than
the min_limit or more than the max_limit of allowable ids in the
ID Manager. |
List all of the groups with ids outside of the limit. |
Not supported. |
| Master entities of contacts/interfaces not defined or
empty |
Checks if there are any contact or interface entities defined
in the model that do not have any entities referred or empty in
the place of master. |
Lists all contact or interface entities that do not have
master entities defined. |
Not supported. |
Opens the Entity Editor of the contact. |
| Slave entities of contacts/interfaces not defined or
empty |
the place of slave. |
slave entities defined. |
Not supported. |
| Slave nodes of contacts/interfaces in master surface |
Checks if the slave nodes of contact or interface are also
present in its master. |
Lists all contacts that have slave nodes that are also
present its master. |
Not supported. |
| Id of element out of bounds |
Checks if there are any element ids that are either less than
ID Manager. |
List all of the elements with ids outside of the
limit. |
Not supported. |
| Duplicate 1D elements |
Checks if two or more 1D elements are connected between the
same nodes. |
Lists all of the duplicate 1D elements. |
Deletes failing elements. |
Not supported. |
| Duplicate 2D elements |
Checks if two or more 2D elements are connected between the
same nodes. |
Lists all of the duplicate 2D elements. |
Not supported. |
| Duplicate 3D elements |
Checks if two or more 3D elements are connected between the
same nodes. |
Lists all of the duplicate 3D elements. |
Not supported. |
| Negative or zero volume of solids |
Checks if a solid has negative volume associated with
it. |
Lists all of the solid elements with zero or negative
volume. |
Not supported. |
| Beam: 3 nodes aligned |
Checks if the beam element nodes IDNOD1, IDNOD2 & IDNOD3
are on same line or co-linear. Or, if the axis node is along the
orientation direction for a beam element. |
Lists all beam element with an aligned 3rd node. |
Not supported. |
Not supported. |
| Master node in other Rigid elements |
Checks if node referred in master entity is also referred in
rigid entity. |
Lists all of the rigid entities that share the node. |
Not supported. |
Opens the Rigid panel |
| Slave nodes in other Rigid elements |
Checks if node referred in slave entity is also referred in
rigid entity. |
Not supported. |
| Rigid element master shares slave nodes |
Checks if same node referred in both master and slave entity
in rigid entity. |
Lists all of the rigid entities that share the same
node. |
Not supported. |
| Degenerated 4 node shells |
Checks if quad (shell) element’s IDNOD2 and IDNOD3 shares
same node IDs |
Lists all of the quad (shell) elements that have IDNOD2 =
IDNOD3 |
Not supported. |
Not supported. |
| Zero slave nodes in Rigid elements |
Checks if slave field of rigid entities have empty or zero
nodes referred. |
Lists all of the rigid entities that have empty slave
field. |
Not supported. |
| Id of node out of bounds |
Checks if there are any node ids that are either less than
ID Manager. |
List all of the nodes with ids outside of the limit. |
Not supported. |
Opens the Renumber panel. |
| Id of system out of bounds |
Checks if there are any system ids that are either less than
ID Manager. |
List all of the systems with ids outside of the
limit. |
Not supported. |
| Id of system collector out of bounds |
Checks if there are any system collector ids that are either
less than the min_limit or more than the max_limit of allowable
ids in the ID Manager. |
List all of the system collectors with ids outside of the
limit. |
Not supported. |
| Id of curve out of bounds |
Checks if there are any curve ids that are either less than
ID Manager. |
List all of the curves with ids outside of the limit. |
Not supported. |
| Repeated X values in curve |
Checks if any X coordinate (abscissa) values are repeated in
FUNCT keyword. |
Lists all curves defined in the model that have repeated X
coordinate (abscissa) values. |
Not supported. |
Opens the Curve Editor. |
| Curve X values not ascending |
Checks if X coordinate (abscissa) values are not in ascending
order for FUNCT keyword. |
Lists all curves defined in the model that have X coordinate
(abscissa) values which are not in ascending order. |
Not supported. |
| Curve has no point |
Checks if there are no X coordinate (abscissa) and Y
coordinate (ordinate) values in FUNCT keyword. |
Lists all curves defined in the model that doesn’t have X
(abscissa) & Y (ordinate) coordinates values. |
Not supported. |
| Id of load out of bounds |
Checks if there are any load ids that are either less than
ID Manager. |
List all of the loads with ids outside of the limit. |
Not supported. |
| Id of loadcol out of bounds |
Checks if there are any load collector ids that are either
List all of the load collectors with ids outside of the
limit. |
Not supported. |
card |
Not supported. |
Not supported. |
