Model Size and Dimensions
Creates three table outputs including - overall model dimension, centre of gravity and inertia of the model and model mass.
- Right-click at the Report or Chapter level and select .
- Below are the properties associated with the Model Size and Dimensions module.
Figure 1.- Name: Provide the name for the Model Size and Dimensions
module.
Basic Options
- Select the Model Mass, Model Dimensions and; Centre of Gravity and
Inertia.
Advanced
- Numeric Precision: Select the number of decimal places.
- Numerical Format: Select the numerical formats - Fixed, Scientific and Engineering.
- Auto Split Table: Provides the function to split up tables automatically based on the space available in the slide or page.
module.
Once executed, a table output for Model Dimensions is generated:
