Mesh Quality Statistics
Creates a table of mesh quality parameters defined in criteria settings file.
- Right-click at the Report or Chapter level and select .
- Below are the properties associated with the Mesh Quality Statistics module.
Figure 1.- Name: Provide the name for the Model Quality Statistics
module.
Basic Options
- Select 2D or 3D or both elements for Mesh quality checks.
2D Quality Checks
- Select the required quality check parameters.
2D Mesh Categories
- Select the required mesh categories such as ideal, good, warm ,fail and worst.
- 3D Quality Checks
- 3D Mesh Categories
worst. Note: User can edit in the mesh quality criteria also in Criteria File Settings in Preferences.
- Advanced
- Numeric Precision: Select the number of decimal places.
- Numerical Format: Select the numerical formats - Fixed, Scientific and Engineering.
- Auto Split Table: Provides the function to split up tables automatically based on the space available in the slide or page.
module.
Once executed, a table output for Mesh Quality Statistics is generated:
