Use the Report tool, formerly known as Automated Reporting Director, to create and export Document and Presentation
reports from within the HyperWorks session.
Create a standardized report from a pre-defined report template that can be reused to execute and export future reports.
A template file saves the Report contents (entities and modules) and the model file data.
Report items consist of several objects that define Document and Presentation reports, such as images, text, and tables.
These entities are the basic building blocks of any report.
Capture and add images illustrating the overview of various entities such as component, property, and materials to
the Model Description section of any report.
Add model statistics to the report in a tabulated form, such as the various entities present in the model and the
number of entities belonging to each entity type.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
component, property, and materials to the Model Description section of any
report.
These entities are present either in the entire model or any specific sections of the model. The
overview of entities is usually displayed by creating a note at each desired entity
with its name.
An Entity Overview can be added to the report at the report level or added to a chapter depending
where you want to see the overview in the report.
Right-click at the Report or Chapter level and select Report/Chapter > Add > Modules > Model Info > Entity Overview.
Below are the properties associated with the Entity Overview module. Figure 1.
Name: Provide the name for the Entity Overview module.
Basic
Options
Model: Select the required page or window from the HyperWorks session.
Note: Since note creation is
only available in HyperView, only
HyperView pages and windows can be
selected in the drop-down.
Entity Type: Select the type of entity that an overview is required
for.
For Assemblies, enter the level of assembly to be captured. Figure 2.
Note: Based on the assembly hierarchy of the model, the
number levels of assembly present in the model populates.
For example, Figure 3.
For Materials and Properties, import the model file along with
the result file and select Advanced from
the Result-Math template drop-down. Figure 4.
For Set, specify the set type. Figure 5.
SETS ID POOL: The sets that are created by using
standard HyperView
capabilities. For example, 1D, 2D, 3D, and orphan node
sets.
User Set: The sets that you create. These sets can
include element set, node set, or component set.
Advanced Options
Entities: Select the entities that this module requires to be
executed. Figure 6.
All: Select all the entities available in the model.
Displayed: Select only the displayed entities in the page or
window.
Hide Displayed Notes: Select this checkbox to hide the currently
displayed notes. Upon execution of this module, the images are captured
only with new notes.
Note Display Options: Select the note display style to be used.
Note: Default note settings are predefined in the HyperView session. For example, refer to the
Model Info note in HyperView.
Capture Images Interactively: Select this checkbox if the images are to
be captured in interactive mode.
Note: You can either reset the notes, which orients the notes to
minimize overlapping of notes on one another, or update the
visibility of notes with respect to displayed entities or both to
aid in the image capture process.
Click Execute.
If the Capture Images Interactively checkbox is not
selected, you can capture only the default image. Figure 7.
If the Capture Images Interactively checkbox is selected,
the Capture Images window is displayed. Figure 8.
Once the notes for the specified entities are created,
use the following options to customize the output image
view:
Re-Position and Update Notes: Reposition and update
the notes after modifying the orientation or zoom
value of the model, or by hiding undesired sections
of the model.
Update Notes: Update the notes after hiding the
unwanted sections of the model.
Re-Position Notes: Reposition the notes after
changing the orientation or zoom value of the
model.
Capture Image: Capture multiple images using this
option.
For example: Figure 9.
Below are a few example outputs of the Entity Overview module.
