Create Reports
Use the Report tool, formerly known as Automated Reporting Director, to create and export Document and Presentation reports from within the HyperWorks session.
Reports can be used to generate, exchange, and present simulation report internally or externally. It is precisely tailored to capture the best practices of the report generation process and is independent of industry and product type. It has been proved to be invaluable to analyze the simulation results such as stress, fatigue, and vibration.
- Create new Document or Presentation reports from scratch based on the company master document. Additionally, save the report template if required. You can also export a PDF version of the report session format.
- Create standardized reports by loading a pre-defined report template.
- Create reports both in an interactive view and in batch mode.
Report Output Formats
- Document Reports
- Consist of a summary of the process or a full report. With the report building elements, similar to the Microsoft Office Word, you can build and export Document reports ranging from a few to hundreds of pages.
- Presentation Reports
- Consists of a few slides to a few hundred slides.
Minimum Software Requirements
| Software | Minimum Version |
| Operating Systems |
| Office Versions | Exported report files can be viewed with any office software
that supports DOCX, PPTX, ODP, and ODT formats. Examples
below:
| .NET Frameworks |
