Safety Menu
Lists options for crash safety modeling.
| Airbags | Create, edit and review airbags. |
| Seat Mechanism | Opens the Mechanism Browser to create and articulate a kinematic mechanism. |
| Dummy Positioner | Opens the Dummy Browser to position a dummy model. |
| Pre-Simulation(Seat Deformer) | Export an input deck, for the appropriate solver, in order to simulate the deformation of the seat under the dummy. Only available in the Radioss and LS-DYNA solvers. |
| Occupant | Shortcut to the Dummy Positioning panel for dummy articulation and positioning. |
| Sensor | Opens the Create sensors dialog. |
| Seat Belts | Opens the Seatbelt Browser to create a complete seatbelt system. |
| Retractor | Create, edit and review retractors on nodes through the Mass panel with elem types set to RETRACTOR. |
| Pretensioner | Create, edit and review retractors on nodes through the Mass panel with elem types set to PRETENSION. (LS-DYNA only) |
| Sliprings | Create, edit and review sliprings on nodes through the Mass panel with elem types set to SLIPRING. (PAM-CRASH) |
| Slip Ring | Create, rename and renumber slip rings. (LS-DYNA) |
| FMVSS 201/ECE-R21 | Opens a Process Manager tab. Only available in the Radioss and LS-DYNA solvers. |
| Pedestrian Impact | Automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time. Only available in the LS-DYNA and Radioss solvers. |
