Constraint Creation Tutorial
Below are the steps to create the constraints required for the tutorial purpose.
- Select Enforced Displacement from Load Type drop down list.
Click Nodes
button.
This will open Node collector panel. -
Using the node selection options, select node ID
528173from the graphics area. -
Click Add
This will add the node entry in the table with the loading direction options.
Figure 1. - Check the box under Select column.
Check
X, Y, Zcheck boxes for the load.This defines that the model will loaded/excited at the selected node inX, YandZdirections. -
Click
Next to continue to Transient Load
Creation task.
Once you clicks Next, SnRD creates load collectors and will be listed in model browser.
