Load Creation
- Load File - select a load definition file. SnRD supports the following file
formats:
CSVTXT
- Add - this will import the load data and create a
Tabled1data in the table - Update - you can update a tabled1 data with a new load definition file
- Entry Selection Options - to perform selection options, like Select All, Unselected All and Reverse Selection for the table entry items
- Refresh Data - to refresh the data in the panel
- Delete options - to delete all or delete selected items in the panel
- HyperGraph plot - you can visualize the Tabled1 data in a HyperGraph chart for a load from the table.
