HyperWorks
HyperWorks
2021
  1. Home
  2. Connectors
  3. Realizations
    View details for different types of realizations.
  4. Fastener Connector Realization Types
    A list of realization types that can be specified for fastener connectors.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Marine
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021
HyperWorks
  • What's New
    View new features for HyperWorks 2021.
  • Get Started
  • Video Tutorials
    Set up your sessions in HyperWorks and create report templates.
  • Geometry
  • Meshing
  • Elements
  • Morph
    Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
  • Connectors
    • Open the Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Define Connector Controls
      Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
    • Create and Realize Connectors
      Use the tools in the Create tool set to create connectors, assign controls, and realize.
    • Realizations
      • Point Connector Realization Types
        A list of realization types that can be specified for point connectors.
      • Fastener Connector Realization Types
        • ConNode (spider)
        • HC cylinder rigid bolt
        • HC cylinder spring bolt
        • RgdBody (spider)
        • RgdBody (spider + washer)
        • bolt (2 cylinder rigid)
        • bolt (BEAM44)
        • bolt (CBAR)
        • bolt (LINK10)
        • bolt (b31)
        • bolt (collapse Rigid)
        • bolt (cylinder bar)
        • bolt (cylinder rigid)
        • bolt (cylinder spring)
        • bolt (general)
        • bolt (spider)
        • bolt (step hole)
        • bolt (threaded step hole)
        • bolt (washer 1 alt) LINK10
        • bolt (washer 1) BEAM44
        • bolt (washer 1) LINK10
        • bolt (washer 1) cbar
        • bolt (washer 1)
        • bolt (washer 2 alt)
        • bolt (washer 2) LINK10
        • bolt (washer 2)
        • clip (washer nodes)
        • clip
        • hinge (b31)
        • hinge
        • wagonwheel
      • Line Connector Realization Types
        A list of realization types that can be specified for line connectors.
      • Area Connector Realization Types
        A list of realization types that can be specified for area connectors.
    • FE Configuration File
      The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
    • Attachments and Connectors
      Attachments are an entity to facilitate the ease of joining subsystems.
    • Autopitch
      Create weld points at a predefined pitch distance so that the model build process can continue without the need to wait for the published weld data from CAD. Autopitch is useful when working with elements, not geometry.
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Design Space
    The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
  • Design Explorer
  • Aerospace
    Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
  • Aeroelasticity
  • Marine
    Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
    Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
HyperWorks
HyperWorks
2021
  1. Home
  2. Connectors
  3. Realizations
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
  • ConNode (spider)
  • RgdBody (spider)
  • bolt (BEAM44)
  • bolt (CBAR)
  • bolt (LINK10)
  • bolt (b31)
  • bolt (general)
  • bolt (spider)
  • bolt (step hole)
  • bolt (washer 1)
  • bolt (washer 2)
  • clip
  • hinge (b31)
  • hinge
  • wagonwheel
