HyperWorks
HyperWorks
2021
  1. Home
  2. Plot Data
  3. Line Chart
  4. Define
    Create and edit curves.
  5. Use Values as a Data Source
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Model Build and Assembly
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Marine
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Text Files
  • Tabulate Results
  • Publishing and Reporting
Index
HyperWorks
2021
HyperWorks
  • What's New
    View new features for HyperWorks 2021.
  • Get Started
  • Video Tutorials
    Set up your sessions in HyperWorks and create report templates.
  • Geometry
  • Meshing
  • Elements
  • Morph
    Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
  • Connectors
  • Composites
    HyperMesh composites modelings.
  • Crash and Safety
  • Design Space
    The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
  • Design Explorer
  • Aerospace
    Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
  • Aeroelasticity
  • Marine
    Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
    Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
  • Panels
  • Results Data
  • Plot Data
    • Working with Plots
      Learn how to maninpulate plot data using the Plot Browser and other user interface tools and options.
    • Line Chart
      • Create Curves by File
        Plot curves for multiple runs and multiple subcases for a component.
      • Define
        • Data Sources
        • MATLAB Interface
        • Dynamic Curve Names
          When creating a curve using the Create Curves by File dialog, the curve name is defined by a Templex expression instead of a fixed string.
        • Add a Curve
        • Copy and Paste Data Point Values
        • Cut, Copy, and Paste Curves
        • Cut Data Point Values
        • Define a Range
        • Display the Curves Dialog
        • Edit a Curve with File as a Data Source
        • Freeze a Curve
        • Freeze and Unfreeze a Vector
        • Insert a Vector into an Active Expression
        • Insert Data Point Values
        • Reference a Curve in the Active Window
        • Rename a Curve
        • Select a Windowing Function
        • Use File as a Data Source
        • Use Math as a Data Source
        • Use Values as a Data Source
        • Turn a Curve On or Off
      • Math
        Create macros that produce curves and notes for plots.
      • Edit
        Edit curves within a specified range and orientation.
      • Values
        Retrieves individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
      • Statistics
        Calculates statistics over a specified range on a curve.
      • Datums
        Add horizontal and vertical datum lines to plots.
      • Notes
        Annotate plots using notes.
      • Move
        Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Move panel.
    • Bar Chart
    • Complex Chart
    • Polar Chart
    • Vector Chart
    • Radar Chart
    • 3D Chart
  • Media Files
  • Text Files
  • Tabulate Results
HyperWorks
HyperWorks
2021
  1. Home
  2. Plot Data
  3. Line Chart
  4. Define
  • What's New
  • Get Started
  • Video Tutorials
  • Geometry
  • Meshing
  • Elements
  • Morph
  • Connectors
  • Composites
  • Crash and Safety
  • Design Space
  • Design Explorer
  • Aerospace
  • Aeroelasticity
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Text Files
  • Tabulate Results
Index
  1. From the Define panel, select Values.
  2. Enter values in the table.
  3. Click Apply.
