poISelectionSet SetDrawStyle
Sets a particular draw style on the current selection set.
selectionSet_handle SetDrawStyle drawStyle
HyperView Tcl Modify
This command sets a particular draw style on the current selection set.
- drawStyle
- A valid draw style is dependent on the selection set 'type'. To obtain a list of valid draw styles for the selection set, use the GetDrawStyleList command on the current selection set.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
# create a selection set of type Element containing all visible elements
set element_set_id [model_handle AddSelectionSet element]
model_handle GetSelectionSetHandle element_set_handle $element_set_id
element_set_handle SetLabel "OurElementSelectionSet"
element_set_handle Add all
puts [element_set_handle GetDrawStyleList]
puts “Current draw style: [element_set_handle GetDrawStyle]”
puts “Current draw size: [element_set_handle GetDrawSize]”
element_set_handle SetDrawStyle [lindex [element_set_handle GetDrawStyleList] 0]
element_set_handle SetVisibility true
# check the graphics area and move the model
element_set_handle SetVisibility false
# create a selection set of type Node containing all visible nodes
set node_set_id [model_handle AddSelectionSet node]
model_handle GetSelectionSetHandle node_set_handle $node_set_id
node_set_handle SetLabel "OurNodeSelectionSet"
node_set_handle Add all
puts [node_set_handle GetDrawStyleList]
puts “Current draw style: [node_set_handle GetDrawStyle]”
puts “Current draw size: [node_set_handle GetDrawSize]”
node_set_handle SetDrawStyle [lindex [node_set_handle GetDrawStyleList] 0]
node_set_handle SetVisibility true
node_set_handle SetVisibility false
# create a selection set of type Part containing all visible Parts
set part_set_id [model_handle AddSelectionSet part]
model_handle GetSelectionSetHandle part_set_handle $part_set_id
part_set_handle SetLabel "OurPartSelectionSet"
part_set_handle Add all
puts [part_set_handle GetDrawStyleList]
puts “Current draw style: [part_set_handle GetDrawStyle]”
puts “Current draw size: [part_set_handle GetDrawSize]”
part_set_handle SetDrawStyle [lindex [part_set_handle GetDrawStyleList] 0]
part_set_handle SetVisibility true
part_set_handle SetVisibility false
hwi CloseStackErrors
This command returns zero (0) if a valid draw style is entered or a value greater than zero if an invalid draw style is entered (or if the selection set handle is invalid).
