HyperWorks Desktop
HyperWorks Desktop
2021
  1. Home
  2. HyperWorks Desktop Reference Guides
  3. HyperWorks Desktop
  4. Tcl/Tk Commands
  5. Tcl/Tk Commands
  6. HyperView
  7. poIGraphicMaterial Class
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Desktop Reference Guides
Index
HyperWorks Desktop
2021
HyperWorks Desktop
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
      • External Readers and Altair Binary Format
      • Generic ASCII Reader
      • Batch Mode
      • External Resources
      • Tcl/Tk Commands
        • Program with HyperWorks APIs for Beginners
        • Object Hierarchy
        • Tcl/Tk Classes
        • Script Use Cases
        • Tcl/Tk Example
        • Program with HyperWorks Tcl/Tk Command Tutorials
        • Tcl/Tk Commands
          • MotionView
          • HyperView
            • Hotspot Finder API Structure
            • Upfront Data Loader APIs
            • poI3DViewCtrl Class
            • poIAdvancedQuery Class
            • poIAssembly Class
            • poIBestView Class
            • poICFD Class
            • poICFD_rake Class
            • poICollisionCtrl Class
            • poICollisionSet Class
            • poIComplexCtrl Class
            • poIComponent Class
            • poIContourCtrl Class
            • poIExplosion Class
            • poIFBDCtrl Class
            • poIFLDCtrl Class
            • poIGraphicMaterial Class
              • poIGraphicMaterial GetAlpha
                Gets the material alpha transparency value.
              • poIGraphicMaterial GetAmbient
                Gets the ambient color of the material.
              • poIGraphicMaterial GetDiffuse
                Gets the diffuse color of the material.
              • poIGraphicMaterial GetEmission
                Gets the emissive color of the graphic material.
              • poIGraphicMaterial GetID
                Gets the graphic material ID.
              • poIGraphicMaterial GetLabel
                Gets the graphic material label.
              • poIGraphicMaterial GetMetallic
                Gets the metallic value of the graphic material.
              • poIGraphicMaterial GetRoughness
                Gets the roughness value of the graphic material.
              • poIGraphicMaterial GetShininess
                Gets the material shininess value.
              • poIGraphicMaterial GetSpecular
                Gets the specular color.
              • poIGraphicMaterial SetAlpha
                Sets the alpha transparency value.
              • poIGraphicMaterial SetAmbient
                Sets the ambient color of the material.
              • poIGraphicMaterial SetDiffuse
                Sets the diffuse color of the material.
              • poIGraphicMaterial SetEmission
                Sets the material emissive color.
              • poIGraphicMaterial SetLabel
                Sets the graphic material label.
              • poIGraphicMaterial SetMetallic
                Sets the metallic value of the graphic material.
              • poIGraphicMaterial SetRoughness
                Sets the roughness value of the graphic material.
              • poIGraphicMaterial SetShininess
                Sets the material shininess value.
              • poIGraphicMaterial SetSpecular
                Sets the specular highlight color of the graphic material.
            • poIImagePlaneCtrl Class
            • poIImagePlane Class
            • poIIsoValueCtrl Class
            • poILayerFilter Class
            • poILegend Class
            • poIMeasure Class
            • poIModel Class
            • poINote Class
            • poIPart Class
            • poIPartAssembly Class
            • poIPost Class
            • poIPostManager Class
            • poIQueryCtrl Class
            • poIQueryDistanceRule Class
            • poIQueryExpressionRule Class
            • poIQueryExtremeRule Class
            • poIQueryIgnoreElemTypeRule Class
            • poIQueryIterator Class
            • poIQueryRule Class
            • poIQuerySetRule Class
            • poIRenderOptions Class
            • poIResultCtrl Class
            • poIResultMathCtrl Class
            • poIScalarDefine Class
            • poIScaleCtrl Class
            • poISCL Class
            • poISection Class
            • poISelectionSet Class
            • poIStressLinearizationCtrl Class
            • poISubcase Class
            • poISweepCtrl Class
            • poISymmetry Class
            • poISystem Class
            • poISystemCtrl Class
            • poITensorCtrl Class
            • poITensorDefine Class
            • poITextAttribute Class
            • poITracingCtrl Class
            • poITrackingSystem Class
            • poIVectorCtrl Class
            • poIVectorDefine Class
          • HyperGraph 2D
          • HyperGraph 3D
          • MediaView
          • TextView
          • HgTrans
          • TableView
      • Translators
      • Result Math
      • HyperWorks Record and Playback
    • HyperWorks Report
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script Exchange
HyperWorks Desktop
HyperWorks Desktop
2021
  1. Home
  4. Tcl/Tk Commands
  5. Tcl/Tk Commands
  6. HyperView
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
Index
Note: See Realistic Rendering and Material Appearance and Entity Attributes in the HyperView User's Guide for additional information.
