HyperWorks Desktop
HyperWorks Desktop
2021
  1. Home
  2. HyperWorks Desktop Reference Guides
  3. HyperWorks Desktop
  4. Tcl/Tk Commands
  5. Tcl/Tk Commands
  6. HyperView
  7. poIPart Class
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Desktop Reference Guides
Index
HyperWorks Desktop
2021
HyperWorks Desktop
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
      • External Readers and Altair Binary Format
      • Generic ASCII Reader
      • Batch Mode
      • External Resources
      • Tcl/Tk Commands
        • Program with HyperWorks APIs for Beginners
        • Object Hierarchy
        • Tcl/Tk Classes
        • Script Use Cases
        • Tcl/Tk Example
        • Program with HyperWorks Tcl/Tk Command Tutorials
        • Tcl/Tk Commands
          • MotionView
          • HyperView
            • Hotspot Finder API Structure
            • Upfront Data Loader APIs
            • poI3DViewCtrl Class
            • poIAdvancedQuery Class
            • poIAssembly Class
            • poIBestView Class
            • poICFD Class
            • poICFD_rake Class
            • poICollisionCtrl Class
            • poICollisionSet Class
            • poIComplexCtrl Class
            • poIComponent Class
            • poIContourCtrl Class
            • poIExplosion Class
            • poIFBDCtrl Class
            • poIFLDCtrl Class
            • poIGraphicMaterial Class
            • poIImagePlaneCtrl Class
            • poIImagePlane Class
            • poIIsoValueCtrl Class
            • poILayerFilter Class
            • poILegend Class
            • poIMeasure Class
            • poIModel Class
            • poINote Class
            • poIPart Class
              • poIPart ApplyDefaults
                Sets the part material to default values.
              • poIPart GetAutoColor
                Gets the part auto color index.
              • poIPart GetColor
                Gets the part color index.
              • poIPart GetDefaultColor
                Gets the part default color index.
              • poIPart GetDisplayMode
                Gets the part display option setting.
              • poIPart GetDisplayModeList
                Gets the list of part display modes.
              • poIPart GetEulerAngles
                Gets the Euler angles with respect to the transform set by the call to poIModel SetRelativeTo.
              • poIPart GetID
                Gets the part's ID.
              • poIPart GetIDVisibility
                Gets the part's ID visibility.
              • poIPart GetLabel
                Gets the part's label.
              • poIPart GetLocator
                Gets the internal locator string for a part (for internal use only).
              • poIPart GetMaterial
                Gets the part material ID (zero if none assigned).
              • poIPart GetMaterialID
                Gets the ID of the material related to a component.
              • poIPart GetMaterialName
                Gets the name of the material related to a component.
              • poIPart GetMeshMode
                Gets the part's mesh mode.
              • poIPart GetOrientation
                Gets the orientation in the local coordinate system.
              • poIPart GetOrigin
                Gets the origin with respect to the transform set by the call to poIModel SetRelativeTo.
              • poIPart GetPartAssemblyID
                Gets the ID for the part assembly that contains a component.
              • poIPart GetParentID
                Gets the part's parent assembly ID.
              • poIPart GetPolygonMode
                Gets the part's polygon mode.
              • poIPart GetPool
                Gets the part's pool label.
              • poIPart GetPoolType
                Gets the part's pool type.
              • poIPart GetPosition
                Gets the position in the local coordinate system.
              • poIPart GetPropertyName
                Gets the ID for the property related to a component.
              • poIPart GetRelativeTo
                Gets the positions relative to the parent assembly, local or global.
              • poIPart GetScale
                Gets the scale factors for each coordinate axis.
              • poIPart GetShadeMode
                Gets the shading mode for a specific part and overrides the global setting that was set with poIRenderOptions GetShadeMode.
              • poIPart GetTracingMode
                Gets the part's tracing mode.
              • poIPart GetType
                Gets the part type's string.
              • poIPart GetVisibility
                Gets the part's visibility.
              • poIPart Rotate
                Rotates the part about the axis and angle.
              • poIPart SetAutoColor
                Sets the part's auto color index.
              • poIPart SetColor
                Sets the part's color index.
              • poIPart SetDefaultColor
                Sets the part default color index.
              • poIPart SetDisplayMode
                Sets the part's display mode.
              • poIPart SetEulerAngles
                Sets the Euler angles (Z-X-Z) with respect to the system defined by the call to poIModel SetRelativeTo.
              • poIPart SetIDVisibility
                Sets the part's ID visibility.
              • poIPart SetLabel
                Sets the part's label.
              • poIPart SetMaterial
                Sets the part's material index.
              • poIPart SetMeshMode
                Sets the part's mesh mode.
              • poIPart SetOrientation
                Sets the part's orientation in the local coordinate system by the given Euler angles ZXZ.
              • poIPart SetOrigin
                Sets the part origin in the local coordinate system by the given vector.
              • poIPart SetPolygonMode
                Sets the part's polygon mode.
              • poIPart SetPosition
                Sets the part position in the local coordinate system by the given vector.
              • poIPart SetRelativeTo
                Sets positions relative to the parent assembly, local or global.
              • poIPart SetScale
                Sets the part scale factors for each axis.
              • poIPart SetShadeMode
                Sets the shading mode. This command overrides the global setting that was set with poIRenderOptions SetShadeMode.
              • poIPart SetTracingMode
                Sets the part's tracing mode.
              • poIPart SetVisibility
                Sets the part's visibility.
            • poIPartAssembly Class
            • poIPost Class
            • poIPostManager Class
            • poIQueryCtrl Class
            • poIQueryDistanceRule Class
            • poIQueryExpressionRule Class
            • poIQueryExtremeRule Class
            • poIQueryIgnoreElemTypeRule Class
            • poIQueryIterator Class
            • poIQueryRule Class
            • poIQuerySetRule Class
            • poIRenderOptions Class
            • poIResultCtrl Class
            • poIResultMathCtrl Class
            • poIScalarDefine Class
            • poIScaleCtrl Class
            • poISCL Class
            • poISection Class
            • poISelectionSet Class
            • poIStressLinearizationCtrl Class
            • poISubcase Class
            • poISweepCtrl Class
            • poISymmetry Class
            • poISystem Class
            • poISystemCtrl Class
            • poITensorCtrl Class
            • poITensorDefine Class
            • poITextAttribute Class
            • poITracingCtrl Class
            • poITrackingSystem Class
            • poIVectorCtrl Class
            • poIVectorDefine Class
          • HyperGraph 2D
          • HyperGraph 3D
          • MediaView
          • TextView
          • HgTrans
          • TableView
      • Translators
      • Result Math
      • HyperWorks Record and Playback
    • HyperWorks Report
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script Exchange
HyperWorks Desktop
HyperWorks Desktop
2021
  1. Home
  4. Tcl/Tk Commands
  5. Tcl/Tk Commands
  6. HyperView
  7. poIPart Class
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
Index
poIPart Class
Note: See Entity Attributes and Component View in the HyperView User's Guide for additional information.
  • poIPart GetColor
  • poIPart GetID
    Gets the part's ID.
  • poIPart GetLabel
  • poIPart GetOrigin
  • poIPart GetPool
  • poIPart GetScale
  • poIPart GetType
  • poIPart Rotate
  • poIPart SetColor
  • poIPart SetLabel
  • poIPart SetOrigin
  • poIPart SetScale
