HyperWorks Desktop
HyperWorks Desktop
2021
  1. Home
  2. HyperWorks Desktop Reference Guides
  3. HyperWorks Desktop
  4. Tcl/Tk Commands
  5. Tcl/Tk Commands
  6. HyperView
  7. poICFD Class
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Desktop Reference Guides
Index
HyperWorks Desktop
2021
HyperWorks Desktop
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
      • External Readers and Altair Binary Format
      • Generic ASCII Reader
      • Batch Mode
      • External Resources
      • Tcl/Tk Commands
        • Program with HyperWorks APIs for Beginners
        • Object Hierarchy
        • Tcl/Tk Classes
        • Script Use Cases
        • Tcl/Tk Example
        • Program with HyperWorks Tcl/Tk Command Tutorials
        • Tcl/Tk Commands
          • MotionView
          • HyperView
            • Hotspot Finder API Structure
            • Upfront Data Loader APIs
            • poI3DViewCtrl Class
            • poIAdvancedQuery Class
            • poIAssembly Class
            • poIBestView Class
            • poICFD Class
              • poICFD AddRake
                Adds a new rake to the CFD Plot/Streamlines panel.
              • poICFD CreateStreamLines
                Creates streamlines for the specified rakes based on the current settings in the CFD Plot/Streamlines panel.
              • poICFD DeleteRake
                Deletes the specified rake from the CFD Plot/Streamlines panel.
              • poICFD DeleteStreamLines
                Deletes the streamlines for the rakes specified in the CFD Plot/Streamlines panel.
              • poICFD GetDataType
                Returns the data type that was used for the streamline creation in the CFD Plot/Streamlines panel.
              • poICFD GetIntegrationMethod
                Returns the integration method that was used for the streamline creation in the CFD Plot/Streamlines panel.
              • poICFD GetMaxBreakAngle
                Returns the threshold value for the break angle between two neighboring streamline segments, which is used to decide if the two line segments should be merged into one, or kept untouched.
              • poICFD GetMaxStepLength
                Returns the maximum integration step length in the CFD Plot/Streamlines panel.
              • poICFD GetNumOfStreamLineColors
                Returns the number of colors in the color map that were used to color the individual streamlines in the CFD Plot/Streamlines panel (when the 'color-by mode' is set to "seed").
              • poICFD GetRakeHandle
                Returns the handle of the rake specified by the rake_id.
              • poICFD GetRakeList
                Returns a list of rake IDs from the CFD Plot/Streamlines panel.
              • poICFD GetStreamLineColoredByMode
                Returns the 'colored-by mode' of the streamlines in the CFD Plot/Streamlines panel.
              • poICFD GetStreamLineDecimation
                Returns whether decimation is being applied to streamlines in the CFD Plot/Streamlines panel, in order to reduce the memory footprint.
              • poICFD GetStreamLineSize
                Returns the size of the streamlines in the CFD Plot/Streamlines panel.
              • poICFD GetStreamLineStyle
                Returns the style of the streamlines in the CFD Plot/Streamlines panel.
              • poICFD SetDataType
                Sets the data type used for the streamline creation in the CFD Plot/Streamlines panel.
              • poICFD SetIntegrationMethod
                Specifies the integration algorithm used for the streamline creation in the CFD Plot/Streamlines panel.
              • poICFD SetMaxBreakAngle
                Specifies the threshold value for the break angle between two neighboring streamline segments, which is used to decide if the two line segments should be merged into one, or kept untouched.
              • poICFD SetMaxStepLength
                Specifies the maximum integration step length in the CFD Plot/Streamlines panel.
              • poICFD SetNumOfStreamLineColors
                Specifies the number of colors in the color map used to color the individual streamlines in the CFD Plot/Streamlines panel (when the 'color-by mode' is set to "seed").
              • poICFD SetStreamLineColoredByMode
                Specifies the 'colored-by mode' of the streamlines in the CFD Plot/Streamlines panel.
              • poICFD SetStreamLineDecimation
                Specifies whether decimation should be applied to the streamlines in the CFD Plot/Streamlines panel, in order to reduce the memory footprint.
              • poICFD SetStreamLineSize
                Specifies the size of the streamlines in the CFD Plot/Streamlines panel.
              • poICFD SetStreamLineStyle
                Specifies the style of the streamlines in the CFD Plot/Streamlines panel.
              • poICFD SetTerminationCriterion
                Specifies the criterion for integration termination in the streamline creation in the CFD Plot/Streamlines panel.
            • poICFD_rake Class
            • poICollisionCtrl Class
            • poICollisionSet Class
            • poIComplexCtrl Class
            • poIComponent Class
            • poIContourCtrl Class
            • poIExplosion Class
            • poIFBDCtrl Class
            • poIFLDCtrl Class
            • poIGraphicMaterial Class
            • poIImagePlaneCtrl Class
            • poIImagePlane Class
            • poIIsoValueCtrl Class
            • poILayerFilter Class
            • poILegend Class
            • poIMeasure Class
            • poIModel Class
            • poINote Class
            • poIPart Class
            • poIPartAssembly Class
            • poIPost Class
            • poIPostManager Class
            • poIQueryCtrl Class
            • poIQueryDistanceRule Class
            • poIQueryExpressionRule Class
            • poIQueryExtremeRule Class
            • poIQueryIgnoreElemTypeRule Class
            • poIQueryIterator Class
            • poIQueryRule Class
            • poIQuerySetRule Class
            • poIRenderOptions Class
            • poIResultCtrl Class
            • poIResultMathCtrl Class
            • poIScalarDefine Class
            • poIScaleCtrl Class
            • poISCL Class
            • poISection Class
            • poISelectionSet Class
            • poIStressLinearizationCtrl Class
            • poISubcase Class
            • poISweepCtrl Class
            • poISymmetry Class
            • poISystem Class
            • poISystemCtrl Class
            • poITensorCtrl Class
            • poITensorDefine Class
            • poITextAttribute Class
            • poITracingCtrl Class
            • poITrackingSystem Class
            • poIVectorCtrl Class
            • poIVectorDefine Class
          • HyperGraph 2D
          • HyperGraph 3D
          • MediaView
          • TextView
          • HgTrans
          • TableView
      • Translators
      • Result Math
      • HyperWorks Record and Playback
    • HyperWorks Report
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script Exchange
HyperWorks Desktop
HyperWorks Desktop
2021
  1. Home
  4. Tcl/Tk Commands
  5. Tcl/Tk Commands
  6. HyperView
  7. poICFD Class
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
Index
poICFD Class
Note: See the CFD Post-Processing and Streamlines topics in the HyperView User's Guide for additional information.
  • poICFD AddRake
  • poICFD DeleteRake
