poISection GetClipAbove
Gets the current direction of the clipping surface (above or below).
poISection_handle GetClipAbove
HyperView Tcl Query
This command returns the current direction of the clipping surface. Returns "True" if the clip is above, or "False" if the clip is below.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Get clip side
section_handle GetClipAbove
hwi CloseStackErrors
Returns false.
