poIImagePlane ClearAlignmentPoints
Clears all alignment points of the image plane.
Imageplane_handle ClearAlignmentPoints
HyperView Tcl Modify
This command clears all the alignment points associated with an image plane.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetImagePlaneCtrlHandle ipc_handle
set ipid1 [ipc_handle AddImagePlane Logo1]
ipc_handle GetImagePlaneHandle imageplane_handle $ipid1
# Add 3 alignment points
imageplane_handle AddAlignmentPoint
# Clear all the alignment points
imageplane_handle ClearAlignmentPoints
puts “Alignment point count is [imageplane_handle GetNumAlignmentPoints]”
hwi CloseStackErrors
None.
