poI3DViewCtrl GetOrtho
Returns the parameters describing the current view in the orthographic projection mode.
viewControl_handle GetOrtho
HyperView Tcl Query
Returns the parameters which define the view when in the orthogonal projection mode. The returned values represent the min and max clipping planes for X, Y, and Z respectively.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
window_handle GetViewControlHandle viewctrl_handle
set ortho [viewctrl_handle GetOrtho]
puts "Ortho: $ortho"
hwi CloseStackErrors
This command should not return any errors.
