File Path Replace
Allows automatic mapping of modified and/or missing file paths and folders in the .xml file.
You can also text edit to map file paths. Color coding shows the status of resolution mapping.
You can open the File Path Replace utility by clicking the
icon in the NVH Assembly
And Analysis toolbar to review the mapping status.
