Model ElementVFORCE defines a general force acting between two markers.
The force vectors is defined by its three components with respect to a third marker. The
components may be defined using MotionSolve expressions
or a user-defined subroutine. They may be a function of any system state and
time.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| id |
Int
| label |
Str
| i |
Reference (Marker) |
Yes |
Yes |
| jfloat |
Yes |
Yes |
| rm |
Yes |
Yes |
| fx |
Function () |
Yes |
Yes |
| fy |
Function () |
Yes |
Yes |
| fz |
Function () |
Yes |
Yes |
| function |
Function ("VFOSUB") |
Yes |
| routine |
Routine () |
| active |
Bool
Yes |
Usage
Vforce is available as
follows:
#1. Force defined in a MotionSolve expression Vforce (i=objMarker, j=objMarker, fx=expressionString, fy=expressionString, fz=expressionString, optional_attributes)
#2. Force defined in a compiled DLLVforce (i=objMarker, j=objMarker, function=userString, routine=string, optional_attributes)
#3. Force defined in a Python scriptVforce (i=objMarker, j=objMarker, function=userString, routine=functionPointer, optional_attributes)
Attributes
Force defined in a
- i
- Reference to an existing Marker object.
- Specifies the marker at which the force is applied. This is designated
as the point of application of the force.
- j
- Reference to an existing floating Marker object.
- Specifies the marker at which the reaction force is applied. This is
designated as the point of reaction of the force.
- fx
- String defining a valid MotionSolve
expression.
- Specifies the MotionSolve expression that
defines the force acting along the x-axis of the reference coordinate
system (see rm below). Any valid run-time MotionSolve expression can be provided as
input.
- fy
expression.
defines the force acting along the y-axis of the reference coordinate
input.
- fz
expression.
defines the force acting along the z-axis of the reference coordinate
input.
- i
- j
- function
- String defining a valid user function MotionSolve expression.
- The list of parameters that are passed from the data file to the user
defined subroutine where the Vforce is defined.
- routine
- String.
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by "∷". The first is the
pathname to the shared library containing the function that computes the
response of the user-defined Vforce. The second is
the name of the function in the shared library that does the
computation.
- An example is: routine="/staff/Altair/engine.dll∷myVforce"
"/staff/Altair/
engine.dll is the DLL
- "myVforce" is the
function within this DLL that performs the calculations
- When not specified, routine defaults to
VFOSUB.
Force and Torque defined in a
Python function
- i
- j
- function
- routine
- Pointer to a callable function in Python.
- An example is: routine=myVforce
myVforce is a Python function or method that can be called from wherever the model
resides.
- The attribute routine is optional.
VFOSUB.
Optional attributes - Available to all variants
- id
- Integer
- Specifies the element identification number. This number must be unique
among all the Vforce objects in the model.
- This attribute is optional. MotionSolve will
automatically create an ID when one is not specified.
- Range of values: id > 0
- label
- String
- Specifies the name of the Vforce object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
- rm
- Specifies the marker in whose coordinate system the torque components
are computed. rm can be on any body, including
Ground.
- The rm attribute is optional.
- When not specified, rm defaults to the global
coordinate system.
- Vforce defined via
expressions.
Vfo1 = Vforce (label="nonlinear bushing", i=m1801, jfloat=m1901, rm=m1903,
fx="-1e3*DX(1801,1903,1903) -2*(VX(1801,1903,1903,1903)**3)",
fy="-1e3*DY(1801,1903,1903) -2*(VY(1801,1903,1903,1903)**3)",
fz="-1e3*DZ(1801,1903,1903) -2*(VZ(1801,1903,1903,1903)**3)")
- Vforce defined in a Python
function.
# Define the user subroutine first
def myVfosub (id, time, par, npar, dflag, iflag):
i = par[0]
j = par[1]
k = par[2]
c = par[3]
# Get the state of the bushing
dx = DX(i,j,j)
dy = DY(i,j,j)
dz = DZ(i,j,j)
vx = VX(i,j,j,j)
vy = VY(i,j,j,j)
vz = VZ(i,j,j,j)
# Compute force
fx = -k*dx - c*(vx**3)
fy = -k*dy - c*(vy**3)
fz = -k*dz - c*(vz**3)
return [fx, fy, fz]
# Define a bushing with nonlinear
damping
vfo2 = Vforce (label= "nonlinear bushing" , i=m1801, jfloat=m1901, rm=m1903,
function= "user(1801,1903,1000.0, 2.0)" , routine=myVfosub )
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
- For a more detailed explanation about Vforce,
see Force: Two Body Vector.
