Model ElementPforce defined in a MotionSolve
expression.
The generalized force acts on all the coordinates involved in the definition of the constraint.
Pforce is available in three different implementations.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| id |
Int
| label |
Str
Yes |
| penalty |
Double () |
Yes |
FD Only |
| penalty1 |
Double () |
Yes |
FD Only |
| unilateral |
Bool
Yes |
| smoothing_factor |
Double () |
Yes |
FD Only |
| function |
Function ("PFOSUB") |
Yes |
| routine |
Routine () |
| active |
Bool
Yes |
Usage
#1. Constraint defined in a MotionSolve expression
Pforce (function=expressionString, penalty=double, optional_attributes)
#2. Constraint defined in a compiled DLL
Pforce (function= userString, penalty=double, routine=string, optional_attributes)
#3. Constraint defined in a Python/Matlab script
Pforce (function= userString, penalty=double, routine=functionPointer, optional_attributes)
Attributes
Pforce defined in a
MotionSolve
expression
- function
- String defining a valid MotionSolve
expression.
- Specifies the MotionSolve expression that
defines the Pforce. Any valid run-time MotionSolve expression can be provided as
input.
- The function attribute is mandatory.
- penalty
- Double
- Specifies a penalty factor to be used in calculating the restoring force
that is used to enforce that the algebraic constraint is always
zero.
- The attribute routine is mandatory.
- Range of values: penalty ≥ 0.
Pforce defined in a compiled DLL
- function
- String defining a valid user function MotionSolve expression.
- The list of parameters that are passed from the data file to the
user-defined subroutine where the Pforce is
defined.
- penalty
- Double
zero.
- The attribute penalty is mandatory.
- routine
- String
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by "::". The first is the
pathname to the shared library containing the function that computes the
response of the user-defined Variable. The second is
the name of the function in the shared library that does the
computation.
- "/staff/Altair/
engine.dll is the DLL
- "myPforce" is the
function within this DLL that performs the calculations
- The attribute routine is optional.
- When not specified, routine defaults to
PFOSUB.
- An example is: routine="/staff/Altair/engine.dll::myPforce"
Pforce defined in a
Python
function
- function
defined.
- penalty
- Double
zero.
- routine
- Pointer to a callable function in Python.
- An example is: routine=myPforce
- myPforce is a Python function or method that can be called from wherever the model
resides.
PFOSUB.
Optional attributes - Available to all variants
- id
- Integer
- Specifies the element identification number. This number must be unique
among all the Pforce objects in the model.
- This attribute is optional. MotionSolve will
automatically create an ID when one is not specified.
- Range of values: id > 0
- label
- String
- Specifies the name of the Pforce object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
- penalty1
- Double
- Specifies a second penalty factor to be used in calculating the
restoring force that is used to enforce that the time derivative of the
algebraic constraint.
- The attribute penalty1 is optional. When not
specified, penalty1 defaults to 0.0.
- Range of values: penalty1 ≥ 0.
- unilateral
- Boolean
- Select one from True and False.
- True indicates an inequality constraint
(unilateral)
- False indicates an equality constraint
(bilateral) is being specified.
- The attribute unilateral is optional.
- It defaults to False when not specified.
- smoothing_factor
- Double
- The penalty force due to a unilateral constraint is ramped up in a
smooth manner using a STEP function. This specifies
the x-value at which the smoothing is completed.
- The attribute smoothing_factor is optional. When not
specified, smoothing_factor defaults to 0.0.
- Range of values: smoothing_factor ≥ 0.
- active
- Bool
- Select one from True or False.
- True indicates that the element is active in
the model and it affects the behavior of the system
- False indicates that the element is inactive in
the model and it does not affect the behavior of the system. It
is almost as if the entity was removed from the model, of course
with the exception that can be turned "ON" when
desirable.
- The attribute active is optional. When not specified,
active defaults to True.
- Particle sliding on a catenary.
XML
<Force_Penalty
id = "1"
label = "Particle on a catenary"
type = "Expression"
expr = "dy (9) - cosh(dx(9))"
penalty = "1E4"
penalty1 = "1E2"
Python
pf1 = Pforce (label="particle sliding on a catenary", function=
"dy(9)-cosh(dx(9))", penalty=1e4, penalty1=1e2)
- Enforce movement of a point P such that it moves in the region
1+x < = y
XML
<Force_Penalty
id = "10"
label = "Enforce 1+x < y"
type = "EXPRESSION"
expr = "1 + dx(10) - dy(10)"
penalty = "1E4"
penalty1 = "1E2"
unilateral = "True"
smoothing_factor = "1.0"
Python
pf2 = Pforce (label="Enforce 1+x < = y", function="1+dx(10)-dy(10)", penalty=1e4, penalty1=1e2, unilateral=True, smoothing_factor=1)
1+x < = z and 1-x ≤
z
XML
<Force_Penalty
id = "1"
label = "Enforce 1+x <=z"
type = "EXPRESSION"
expr = "1+dx(10)-dz(10)"
penalty = "1E4"
penalty1 = "1E2"
unilateral = "True"
<Force_Penalty
id = "2"
label = "Enforce 1-x <=z"
type = "EXPRESSION"
expr = "1-dx(10)-dz(10)"
penalty = "1E4"
penalty1 = "1E2"
unilateral = "True"
Python
pf3 = Pforce (label="Enforce 1+x < = z", function="1+dx(10)-dz(10)", penalty=1e4, penalty1=1e2, unilateral=True, smoothing_factor=1)
pf4 = Pforce (label="Enforce 1-x < = z", function="1-dx(10)-dz(10)", penalty=1e4, penalty1=1e2, unilateral=True, smoothing_factor=1)
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
- For a more detailed explanation about Pforce,
see Force: Penalty.
