RV
Model ElementRv defines a special type of solver state variable. It is used in the evaluation and computation of design sensitivity as a response variable.
Class Name
Rv
Attribute Summary
| Name | Property | Modifiable by command? | Designable? |
| id | Int () | NO | NO |
| label | String () | ||
| ic | Double () | ||
| function | Function () | ||
| routine | Routine () |
Usage
Rv (ic=0.0, function="USER()", routine=self.routine, optional_attributes)Attributes
- id
- Integer
- label
- String
- ic
- Double
- function
- String
- routine
- String or a pointer to a Python function.
Rv(ic = 0.0, function = 'DZ({I},{J},{J})'.format(I=marker.id,J=part.cm.id))Response Classes
- DeviationSquared
- Used to compute a response which is the difference between a function's current value and a desired value.
- GenericResponse
- Most generic case. A layer over Rv element, it connects response variables given as a function or through a sub-routine to plotting and optimization.
- ResponseExpression
- Used to compute user defined algebraic expressions containing response and design variables as response.
- MaxVal
- Computes the maximum value of a user specified function. The function could be a MotionSolve expression or a user subroutine.
- MinVal
- Computes the minimum value of a user specified function. The function could be a MotionSolve expression or a user subroutine.
- RMS2
- Used to compute a response that is the root mean square area difference between a measured curve and a target curve.
- Slope2
- Used to compute a response which is the slope of a curve that is drawn between two quantities at a particular time point.
- Slope2Deviation
- Used to compute a response that measures the deviation from a desired value of the slope of a curve that is drawn between two quantities.
- ValueAtG
- Used to compute a response that is a value of a signal when second signal achieves a certain value.
- ValueAtTime
- Used to compute a response that is a value of a signal at a particular time.
