Text File
Add a text file to the report.
- Right-click at the Report or Chapter level and select .
Or
From the Report ribbon, click the arrow next to the Add Item, then select Text File.
- Below are the properties associated with the Text File entity.
Figure 1.- Name: You change the name property of the text file item.
- File Path: Select a text file using the file browser option. Note: The text file entity imports the data from the selected text file and inserts it into the exported report. The imported text is assigned default font in the report.
