Align Midmesh
Use the Midmesh: Align tool to align the midmesh.
From the Mesh ribbon, click the Midmesh > Align tool.
Figure 1. - Optional:
On the guide bar, click
to define alignment
options.
Align midmesh.
To align Do this Face to surface - Set the Source selector to
Elements, then select elements.
- Select 2D elements to align face to surface.
- Select 1D elements to align edge to surface.Restriction: Only T-edge 1D elements can be selected.
- Use the Guide A selector to select first surface to align to.
- Use the Guide B selector to select second
surface to align to.Note: Guide B is optional and used to align between two sets of faces.
- Click Align.
Node to lines - Set the Source selector to Node List, then select nodes.
- Use the Guide A selector to select first line to align to.
line to align to.Note: Guide B is optional and used to align between two sets of edges.
- Click Align.
