Select a Loadcase
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Create an assembly structure from a .csv file definition.
The results post-processing workflow is now embedded in HyperMesh, and you can seamlessly process solver native results in HyperMesh. The File Loader is used to generate the new results entity.
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
Enables exploring the element force and moment results (internal loads) from solver result files (grid point forces) for further component sizing/optimization tasks and also for component certification/margin calculation.
Calculate free-body forces, moments, displacements and rotation.
Calculate the contribution of one or more elements to the force and moment equilibrium at desired nodes.
Plot displacements and rotations at nodes.
Define a cross-section plane.
Display free-body forces and moments at each cross-section along a node path.
Potato plots are used to build load envelopes. VMT plots are used to build tensile, shear and bending moment diagrams.
Display normal and shear loads of panel structural members.
Define visualization options for the panel plot.
Display forces and moments acting on beam and bar elements.
In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results. This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
Use this tool to evaluate for the selected elements the average value of the selected result type.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
