Motorcycle - Trailing Arm - Twin Shock
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
The vehicle library is installed as a part of the normal HyperWorks installation.
Front suspension systems support the wheels in the front with the help of strut rods.
Rear Suspension systems support the rear wheel with the help of a swingarm and coil springs.
A powertrain based on a linear curve where the torque generated is directly proportional to throttle applied.
Jounce and Rebound bumpers restrict the upward and downward movement of suspension components.
Rider plays an important role in two wheeler dynamics. To capture the effects of rider on a vehicle, it is important to have a good human body multi-body dynamics model.
The driveline transmits the power from the power source to the driving wheel.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
